PerryV 0
Just starting with Fibaro domotica and built a test board with several lights, dimmers and switches. Needed a trigger to start a scene, so used Dimmer 2 and a switch in 3 wire mode. However forgot to attach a load, as mentioned in the manual ;-(.
Since then I'm not able to switch on the lights anymore by dimmer output. The red light on the Fibaro module is red, it reacts to reconfiguring by webinterface and by menu options with the B-switch. Did I damage the output, or do I need to check all the parameters, since calibration failed? I try to recalibrate, but it doesn't seems to work. Thanks in advance.
13 answers to this question
