It looks like weather is not updated.  It is 2 degree but in reality it is 10.
Know issue?
Edited by barend121
add tags
Hi @barend121!
What version of software do you have?
I suspect that you are talking about that little icon in the top-right corner?
    Jup talking about that
    running latest Stable version
    But the yr weather is also wrong :-)
    Edited by barend121
    Reboot did the trick.. but after 7 days up, not a good sign.. Anyone else having this problem?
    Hi @barend121,
    Here is picture of all three weather plugins on my HC2:
    Weather provider is set as default and I update it with my Weather State VD. As you can see YR weather is off while Yahoo is much more close. Temperature, humidity and wind shown on Weather provider is from my Netatmo weather station, while weather status icon is updated according to data collected from openweathermap.org.
    I use two Weather state VD and two Weather forecast VD:
    On the left are Weather state VD (above) and Weather forecast VD (bellow) that collect data from openweathermap.org while on the right are collecting data from wunderground.com. All this is working reliably for long time and I hope I will soon publish this new versions.
    I know this does not help you with current problem, but this is much better solution than just Fibaro plugin. Not only that I have complete weather report, but have also forecast for several days in advance with push and popup messages and can monitor weather for more than one place what can be very handy for people that travel frequently as an example.
    There is something wrong with updating the weather! It does not  update anymore.
    Edited by barend121
    looks like it is updating again! anything changed?
    Stops updating again! Mmmmmmm
    • 1 month later...
    Hi all, @Sankotronic
    I tried to find similar topic, but without expected success. I'm wondering if it is possible to import the "OUTDOOR AIR QUALITY" indicator from NETATMO sensor to the LUA scene via API?
    Has anyone of you tried similar solution or maybe wrote a scene which can perform such action? Your advice would be much appreciated.
