[SOLVED]Virtual devices
is there a way to have 2 buttons for VD's on the UI?
Two buttons like a regular light (on/off).
any suggestion are welcome
I use a single button with logic in the lua code.
if device x is on then
turn off device x
elseif device x is off then
turn on device x
Place this type of code behind one button and set it as the main button for the VD.
    turn off device x
    turn on device x
    Thanks Robert,
    that's a nice work around.
    More nice would be if Fibaro would grant the option to have to buttons.
    Anyhow, as long there is no other way I will use your way. :)
