[SOLVED]How to clear 999+ push notifications?
Please help!
I added a scene a while back to test push notifications to a mobile phone.
Long story but basically I left it running and now theres 999+ notifications on my Android app (see screenshot).
Does anyone know how to clear the "Current" notifications?
There's too many to clear individually.
I tried deleting the mobile device in HC2 and re-adding it.
Also tried deleting the Android app data.
Thanks, Elton,
Link to post
6 answers to this question
9 hours ago, samuel said:
in the current tab you are not able to do a clear all, only in the history tab, as long I know
That is correct, unfortunally I havent found a solution for it as well, and it can drive me nuts, even with only 150 message allerts on my mobile
Link to post
Hi @earto!
You wrote that you removed app data. However, did you remove and install the whole app again?
Did you clear your network data?
Finally, you can try this LUA code:
You can check how many notifications (and their IDs) you have here:
http://<IP>/api/notificationCenter
Link to post
  • 14 hours ago, I.Srodka said:
    Hi @earto!
    Hi @I.Srodka,
    Thanks so much for your reply.
    In the notification center there are no notifications listed.
    But your LUA code gave me a hint.
    I didnt try your code yet because there wasnt anything listed.
    Maybe I need to be clearing it using HomeCenter.PopupService.remove(id) somehow?
    To clarify, I sent the notifications as "Info" using this LUA code:
    Sorry, I just realised that maybe I called it the wrong thing - it shows as "Notifications" in the app!
    I cleared the data in Android by going to settings, apps and then "Clear Data" and "Clear Cache".
    After this I restarted the App and its like default, you have to enter the passwords again and find the HC2.
    But the notifications all came back again.
    Thanks, Elton.
    Link to post
  • Thanks anyway @I.Srodka.
    I might give one of my kids some pocket money to press the keys - I know its a minimum of 2000 key presses (message and OK).
    Who knows how many there are, I've read 300 already and it still says 999+....
    Link to post
