I want to trigger a scene whenever the global variable change value. The values of the global variable are are "0" or "1" .
The test scene is :
The scene is not activated automatically by change of the global variable "GlobalVariable".
If I run scene manually it reports correctly the value of the global variable.
Any hint ... ?
4 answers to this question
How do you change the global variable ?
    It is changed by API call from external PHP script.
    I have solved this out in the way, that I update the global variable, and after this I call the scene to be run (from my PHP script).
    @gucio1234, you have to set property "invokeScenes" to True for making scene triggered by global variable witout additional php script to start a scene.
    Topics i metioned that.
    @jakub.jezek  thank you for your links :)
