HomeCenter.SystemService.reboot not working from scene in version 4.140
I'm using the Satel alarm integration. The integration is great, but the HC2 just isn't very stable (Satel events are not coming in anymore after a day or 2), so I restart it every night using HomeCenter.SystemService.reboot in a scene. But as of version 4.140 the HC2 does not restart. I've added debug code to the scene and the method is called, but the HC2 just won't restart. It seems to ignore the call completely.
Any ideas?
8 answers to this question
Hi @XanderF!
You probable have something wrong in the schedule loop, please try this code (it's a reboot at 2 AM):
@Vinisz, you probably have similar issue ; )
Is there any way to reboot HC2 from a scene?
I would like to do it daily but all commands user so far are not working ( v 4.510 )
I use this code in a scene: HomeCenter.SystemService.reboot();
It works when I kick of the scene manually, but it doesn't work when running scheduled.
Do you have exactly the same experience ?
    Thank you. Not sure what was wrong with my lua code, but the code above is working perfectly :D.
    What about
    In VD? It does not work.
    for me it's also not working from the scene.
    i have VD which works if triggered manually.
    Anyone has solution to automatically reboot?? on latest 4.510 firmware
    Guest andyhud
    On 11/15/2017 at 3:20 PM, I.Srodka said:
    Hi @XanderF!
    Does anyone know if this code works on Firmware 4.510? Has anyone tested it?
    Ta
    Andy
