XanderF 8
I'm currently using HC2 version 4.144 and installed two heat controller. One with external temp module and one without it. After adding a heat controller I get two images, one of the heat controller itself and one thermometer. There are a couple of weird things:
1. The temperature of the heat controller with external temp module is correctly displayed by the thermometer image in the FibaroHome app (iOS), but is always displayed on the HC2 webpage as two dashes "--".
2. The thermometer of the heat controller without external temp module always displays two dashes "--". I expect it to display the current temp of the internal thermometer of the heat controller.
Anyone else having the same issues?
14 answers to this question
