[SOLVED]Amazon Echo Dot can’t discover my devices
hongsit
Hi, hopefully posted this in the right place.  I had a Home Center Lite and my Echo Dot was setup with all my fibaro devices and it worked great.  I’ve recently migrated to a HC2, removed all my devices from HCL and added them in the HC2 one by one.  Setup my HC2 with remote access and registered in my Fibaro ID.
In my Alexa app I removed all my previous devices from the HCL (had to do this via as it won’t remove the via the iPhone app) and tried to discover the smart devices again.  However, Alexa can’t find any of my devices in the HC2 and can’t find any scenes either.
my network is ok, noth8ng has changed in that respect.  Does anyone know if there’s a current issue between amazon and Fibaro?
ive tried rebooting both Echo and HC2, removing HC2 from fibaro Id, reconfigure devices, disabled and enable fibaro skill, all of this and in different orders.
Don’t really know what else to do or try, can someone with the same setup check to see if yours are working?  I’ve had experience downtime with the service before, so hopefully it’s just that.  Hope someone could confirm so I can stop wasting my time on this and start writing some Luca scripts :-)
4 answers to this question
Hello @hongsit!
It looks as if you have done everything you could, maybe just the sequence order could be different.
However, it would be best to check your case. In order to have it checked, please send me via PM your HC serial number and Alexa region.
Hi @hongsit!
To engage with new set of devices, you should begin with
Quote
Alexa, list home center devices (this one requires FIBARO Custom Skill)
And then you can do the rediscovery (discover devices).
You're also welcome to read our knowledge base articles about Alexa:
  • Thanks, got it working.
    Alexa did not automatically pick the one and only Home Center in my Fibaro ID.  It remembered my HCL and I had to literally ask Alexa to change to the one and only HC2 device by asking it to List Home Center Device as you stated.
    Thanks you @I.Srodka
