I have the following code:
I want to accomplish the following idea:
if the temp is between 18.1 - 18.9 then
     1 digits after comma
else
    If the bathroom temperature is example 18.0 / or 18 then it should show only zero digits after the comma
Any help would be appreciated ? :-)
(temperatures are examples, it can be any temperature)
else
Like this?
/Peo
    The temperature comes from heatit thermostat, So, the temperature will not stay between 18-19 degrees celcius but will change. Thats why i mention that the (temperatures are examples, it can be any temperature) because of the sensor
    Your script is fixed between 18-19 degrees
    But i will test your script first~
    Tested the script~
    This not exactly what I was looking for.
    on my iphone in an VD, normally my outlining is on the right from the text (normally left outlined)
    I fixed this by putting spaces in text so that the line will be outlined to the right.
    but if a value is 18 then it needs one space to the right compared to a value like "18.6" Thats what I like to accomplish
    when the bathroomtemperature is 18 it needs to see that there is a zero  18.0 or none  (18) the rest what is in between 18.1 - 18.9 will normally be displayed
    of course not only by 18, but by all temperatures, because the sensor displays not only  a value of 18-19 but also outside this range
    Looking forward for a solution
    This is working for me:
