Scene Activation sets lights to 100% breifly
For certain modules when I double press to activate a scene the light comes on at full brightness breifly before the scene kicks in and puts it to the desired brightness. I know I can switch off the parameter setting the double click to do this but when I deactivate the double click it also stops it from running the scene. Its really frustrating, and happens on both dimmer versions (1&2). it only happens in certain rooms but I cant see any difference in the parameters, other than I have disabled the double click in the rooms that behave correctly. As I said I'm happy to do this in the rooms that aren't working but then I get no scene activation at all.
Any help would be great,
thanks
tom
Hi @tvs ,
Is the problem still present or have you found a way to solve it? Have you tried contacting our support?
If not, please show me the scene that you've created so that I can see what we're working with.
