jimt
Flood sensor ZW5 on Smartthings hub
I have installed the flood sensor using external power supply.  The sensor is connect Samsung Smartthings Z Wave Plus hub.  The sensor status was dry and available upon installation.  Now the sensor shows Unavailable on Smartthings.  If I move the sensor it will report motion trigger and then return to dry status.  Why does the sensor stop reporting availability?  Should I be concerned the unavailable status means flood detection will not trigger? Device Health is set to On in the hub
Is this the expected behaviour?
Share this post
Link to post
