Ananta Creation 0
I am using HC-2 to configure all my Home Automation system.
I have created Virtual device to control IR devices. As to show case Lable I need to code using Lua.
Can any one tell me what's wrong with following Lua code.
local hc = fibaro:getSelfId();
local ip = fibaro:getValue (hc, 'IPAddress');
local port = fibaro:getValue (hc,'TCPPort');
tcpSocket = Net.FTcpSocket (ip,port);
fibaro:debug(hc);
fibaro:debug(ip);
fibaro:debug(port);
tcpSocket:setReadTimeout(3000);
tcpSocket:write("sendir,1:1,1,36337,1,1,95,33,16,16,16,16,16,32,16,32,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,32,16,16,16,4651\r");
tcpSocket:disconnect();
fibaro : call(hc, "setProperty", "ui.Label1.value","20°C");
For debugging purpose, I have used socket tester. On it, some time I am able to receive string, some time not. Some time socket connection remain open.
Can any one help me.
Is there any possibility to have problem with router?
