Showing results for tags 'hc-2'.
Found 5 results
  1. Hi, How can I migrate my HC-2 from 1.170 to 1.160 version. Currently my Z-wave network is not functioning properly. And I am not getting any proper help from Fibaro Support. If any member has face such issue then please help me to sort out. For kind information, every devices is working perfectly from last 2 years. I am facing this issue from last 2-3 days. My all devices are located with in 15 Feet distance from HC-2.
  2. Hi, I have HC-2 and have around 50 scene for different actions. Everything is working fine till last few days. Now when ever I trigger scene for 1st time it got executed but after that, if trigger new scene (Like, I have trigger ALL ON scene first and then Mood Light Scene. In this case execution of Mood light scene takes 15-20 second. Which was working perfectly before ) then it takes 15-20 second to execute it. This same situation occur when I trigger scene via Android Phone, iPad or Keyfob. So I think it's problem with fibaro Hc-2. Note : I have included Keyfob and Swipe on that day. Also I am unable to have remote access from last one day.
  3. Today my HC2 stopped working twice , nothing was working anymore . Was not able to acces my HC2 as well. Have to shutdown the HC2 manually and startup again. After a view minutes was able to acces my HC2 and everything was working again. I am running 4.153 Beta version. Has anyone have seen the same problem and is to be solved and how. Is there a possibility to see in any logs ??? why my HC2 is stopped. Is there a possibility to install a watchdog so i can get a message when the Hc2 stops. Thanks in advance
  4. Hi, I am using HC-2 to configure all my Home Automation system. I have created Virtual device to control IR devices. As to show case Lable I need to code using Lua. Can any one tell me what's wrong with following Lua code. local hc = fibaro:getSelfId(); local ip = fibaro:getValue (hc, 'IPAddress'); local port = fibaro:getValue (hc,'TCPPort'); tcpSocket = Net.FTcpSocket (ip,port); fibaro:debug(hc); fibaro:debug(ip); fibaro:debug(port); tcpSocket:setReadTimeout(3000); tcpSocket:write("sendir,1:1,1,36337,1,1,95,33,16,16,16,16,16,32,16,32,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,32,16,16,16,4651\r"); tcpSocket:disconnect(); fibaro : call(hc, "setProperty", "ui.Label1.value","20°C"); For debugging purpose, I have used socket tester. On it, some time I am able to receive string, some time not. Some time socket connection remain open. Can any one help me. Is there any possibility to have problem with router? AC_Temp.vfib
  5. Hi, I am using Global cache (WiFi2IR) to control my all IR devices with Fibaro HC-2 (4.140). 1. When there is no internet at that time HC-2 is not able to communicate with Global cache. 2. Certain time i have to press VD button multiple time to send proper IR command.
