Showing results for tags 'global cache'.
Hi All, I'm having some issues when creating a virtual device in Home Centre using a Global Cache iTach Flex with the Tri cable to 3 devices, projector in port 1, amplifier in port 2 and receiver in port 3. In the Global Cache learning software when I learn in the correct signal and then send it from there to test it works perfectly. Once I add them into Home Centre only the projector in port 1 is working correctly and ports 2 and 3 are completely unresponsive. I have added the correct bit to the end of the string for Fibaro on all of them and I have made sure that when learning the string the correct connector number is selected. Has anyone else had success in making this work? There should be no issues with the Global Cache as its working fine on their software so it is obviously able to send it to the correct devices, the Fibaro just isn't able to replicate that.
Best product for IR and RF 433/315 to control from Fibaro, email [email protected] for more details
How can I add button in virtual device ( Remote for TV), by pressing it I can send command for channel No. Ex. Button Name MTV - which will send IR code for digit 2,3,4
- 1 reply
- global cache
- virtual device
Sending serial commands to Global Cache iTach Flex (RS232/RS485)
jakub.jezek posted a question in Home Center 2
Hello guys, I ran into interesting problem. Honestly i do not know if problem is in Fibaro or Global Cache, so i need some help. Ticket in partners dedicated channel: #95470. I'm doing VD for a customer (Fibaro dealer) for control of Somfy RTS module (VD is below). But i'm able to receive only 8 comands, then it seems like connection get stucked. If i send commands from iTest (global cache app), that i am not a problem to receive more than 8 commands. If i send commands from Fibaro to PC directly (Hercules app can be set as TCP server), then i'm able receive more than 8 commands (Same port and protocol, just diffrent IP adress). I'm sending those serial commands (RS-232/RS-485) to my Laptop to application Hercules (Link below). Global Cache i'm using is iTach Flex IP. Cables connected are Flex Link RS-232 cable and Flex Link RS-485 cable. I tested it with both. As RS-485 to USB converter i'm using something like that: http://www.rockonpro.pl/monacor-da-70157 or this one (rs-232) http://www.aten.com/global/en/products/usb-&-thunderbolt/usb-converters/uc232a/#.WWNf3ulpzg4 @T.Konopka or @M.Baranowski, can you look at this one please? Global Cache Cables: https://www.globalcache.com/files/docs/DS_FLC-SL_final.pdf Hercules app link: http://www.hw-group.com/products/hercules/index_en.html Virtual device: Somfy_RTS.vfib -
Hi, I am using Global cache (WiFi2IR) to control my all IR devices with Fibaro HC-2 (4.140). 1. When there is no internet at that time HC-2 is not able to communicate with Global cache. 2. Certain time i have to press VD button multiple time to send proper IR command.
- 4 replies
- virual device
- global cache
Hello Guys, I just found this https://www.globalcache.com/press-releases/global-cache-introduces-new-modular-product-line/ while browsing the internet. In a general and looking. What do you think about new Glabal Cache devices? For me big plus for HDMI switch if it will have some decend API. And it looks it has ethernet pass through.
- 2 replies
- global cache
- global connect
Hi, Looking for some help with some VD code for a Global cache GC-100-12 as I can seem to get anything to work My TV is connected to IR Port 3 on the gc device i used the GCIRE learner for the power button on the remote This is the string I got sendir,1:1,0,40000,1,1, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,4018 in the iLearn app the first two lines are colored - not sure what this means but I took the whole string..... I changed the second number after the sendir from sendir,1:1 to sendir,1:3 as I am using port 3 on the GC unit (I also changed this to 1, 2, 3, 4, 5, 6 and none of them work) I created a VD with the following I included both 0x0D and 0x0D0x0A at the end of the sent string and neither worked I also tried some lua code in a VD with the /r at the end and no luck with that either fibaro:log("Connecting..."); fibaro:debug("Connecting..."); local selfId = fibaro:getSelfId(); local ip = "192.168.1.111"; local port = 4998; tcpSocket = Net.FTcpSocket(ip, port); tcpSocket:setReadTimeout(1000); -- POWER -- tcpSocket:write("sendir,1:3,0,40000,1,1, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,1029, 96,23,48,23,24,23,48,23,24,23,48,23,24,23,24,23,48,23,24,23,24,23,24,23,24,4018\r"); fibaro:sleep(2000); result, err = tcpSocket:read(); tcpSocket:write("END"); if (err == 0) then fibaro:log("transfer OK"); fibaro:debug("transfer OK"); fibaro:log("Please Wait..."); fibaro:sleep(5000); else fibaro:log("transfer failed"); fibaro:debug("transfer failed"); end tcpSocket:disconnect(); finally i tried a reboot in case I had too many socket connections open but that didnt make any difference Would somebody that has this working have a look and perhaps let me know where I have gone wrong Thanks -frustrated
- 2 replies
- global cache
- gc-100
