Archidee 0
Still looking forna solution to control
dimmed lights wired or wirelessly from extra/different switch wall box.
since the number of cables is insufficient in the different wallboxes required to connect multiple pulse switches in parallel to control lights connected to a dimmer 2 I am looking for alternative solutions.
Would it make sence to use a 2nd (and 3rd and 4th) Dimmer 2 without lamp or load to be paired over zwave to a first Dimmer 2 just as a ‘virtual switch’?
would that work if there is no balast?
