Turning scene on and off manually
How can I make a scene that only turns on/off with a manual trigger like a switch on the phone. I would like to have a movie scene that i can turn on only with the phone ore computer that vill turn of or dim the lights. Every time I try to make a scene I need a trigger device....?
Alex
11 answers to this question
@Alexjuul
1) Create a Global variable - say MovieSceneStatus: Value 0 and 1, where 0 would be off and 1 would be on.
2) create a scene with following.
if ( fibaro:getGlobalValue('MovieSceneStatus') == "0"  ) -- scene is currently OFF
 then
  fibaro:call("light1ID", "TurnOn")
  fibaro:call("light2ID", "60")
  fibaro:setGlobal('MovieSceneStatus', "1")  --  define the scene to be ON.
    else
      -- if it is already ON, you probably want to turn things off
     fibaro:call("light1ID", "TurnOff")
     fibaro:call("light2ID", "0")
     fibaro:setGlobal('MovieSceneStatus', "0")  -- define the scene to be OFF
Save the scene and set it as manual so you can use PC or Mobile to "play" the scene manually.
Is this what you are looking for?
Edited by Sirhideo
@Jamie mccrostie and this is one of the reasons why block scene needs an else function..
yep
@Alexjuul
check out these two links
    So it is not possible to make this function on HCL?
    Here is an example of what I would like to make. Example the movie function.
    Hi
    Here's a scene with a widget, I think that's what you're looking for.
    Create a variable "Dummy1" and follow the screenshot.
    Ok, yes it looks that way. Thank you. This meens that on the HCL you. An not make a scene with bouth on and of button like you see on my picture, tou actually need to make on schene for eatch function....... by the way hTiger, are you scandinavian? Looks like danish language on your screen shot?
    Hi
    I'm from Denmark, see under profile picture.
    You make a scene and widget to turn off.
    Please try this here.
    Maybe you can use only 1 scene.
    Edited by hTiger1
    Ja, det har jeg også lurt på hva den verdien du kan skrive inn i det grønne feltet du viser til....hva er den for?
    Hi
    Try making some tests with different settings and try also "opposite state".
