Can anyone tell me how many 15W LED with power factor 0.9 can be connected with fibaro double channel relay?
If possible share calculation formula for same.
6 answers to this question
None according to Fibaro  manuals, resistive load only.
You need to slave a relay.
Hi @Ananta Creation!
Just as @Jamie mccrostie said, it's not recommended to connect LED lights.
We have a special product for this: Dimmer 2
Of course, you can always use contactors but then you won't have energy consumption metering.
@I.Srodka About energy consumption metering, since most of us use leds and contractors please bring us an update that allow to declare our module consumption like old modules has.
Will be nice to have an option that show module consumption or declared.
I think many will enjoy this!
Make a pool and ask.
That's of course an interesting idea but since this module has a real power metering capabilities, we didn't want to spend time on adding some fake/simulated consumption features. However, I raised the issue that some people would be interested in this feature.
Finally, you can always use the dimmer ; )
In the foreseeable future I don't see this feature being implemented.
@I.Srodka, i use Fibaro relay and 3 phase contactor for swimming pool pumps, i can't use dimmer :).
My consumption is around 3 kw/h, so an option that let me declare my consumption will be great.
Yes,please add this. For several devices including underfloor heating and AC, which in my case do not report energy consumption, i would like to manually declare based on on/off state. Please add this feature! The energy panel is useless without these high-power devices also monitored.
