Are you planning on integrating with Bluesound? Their multiroom audio system is known for being on par, if not better, with that of Sonos. I personally prefer it over Sonos as Bluesound has products that are much more open and compatible with TV setups.
Thus, it would be greatly appreciated that I could apply some home automation with the Bluesound system as well.
Thanks!
Hi @saucy,
If you know about some open api for blusound, then i would suggest to make request to Fibaro support. They send it to right person responsible for integration.
  • 4 weeks later...
hi!
I just created a virtual device for it:
@jakub.jezek
The api is described here:
As the VD is pretty limited, a Fibaro Plugin would be really great!
Edited by doezel
