Guest Bastian
i had installed a double switch 2 in a two-way curcuit. The function over the Fibaro app and scenes are Ok.
But if turn on or off the lights manually with the wall switch there is a delay of reaction/of turning of the lamps of 1 second. Without the double switch there is no delay.
Is this a "normal" reaction/restriction with which i have to live or could i change this in parameters of the double switch?
Just for info: the double switch is just 2 meters away from the HC2 installed so i think it is not an range promblem.
Thank you and best regards
5 answers to this question
