Login problems after deleting one oser
So, I had two identical users, deleted the one not being superuser, and now I can't get into the box,
any suggestions ?
Is there a hard reset button, and seriously, this is my second system, got Fibaro because it was supposed to be easy with web logins to the different ones :-)
7 answers to this question
    Thinking about it, you should not be able to delete the last user on any system, should you?,
    this must be s bug.
    Never mind, started from scratch now...
    And now, reset is not working, sigh......
    How do I reset the bloody thing?
    The reset manual instructions is not working.
    So much for a easy small temp control solution during the weekend....
    @Soft, why did you post the issue here? Did you read the description and guidelines for this category?
    Description of the category:
    Quote
    Comments and ideas about Fibaro community
    Rules and guidelines of the category:
    Quote
    This forum is dedicated for ideas and suggestions about the Community itself.
    1. Avoid duplicates - search the category for similar topics first. Duplicates will be closed immediately.
    2. Please, remember to be as factual and to the point as possible. Meaningless posts will be hidden immediately without any notice.
    3. Watch your language!
    Read descriptions in order to post in proper categories.
    Here you have a link to our Knowledge Base where recovery mode is explained
    " to "
    Temat został przeniesiony z "
    " do "
    Ok, I'm sorry for posting in the wrong section, thought I got it right.
    If you have read what I wrote"The reset manual instructions is not working.", at least not for me, so pointing to the manual on how to reset, was not of any help.
    I still haven't been able to use the reset function, might have gone into fixed IP mode, even if I used a timer every time I tried, to avoid that.
    AND, the initial question was how can it be possible to delete one user, and thereby kill the whole thing?, that was the question I would have liked you to comment on.
    If this is the case, make sure you inform users not to remove the last user, admin/superuser should be protected.
