Heating panel / Main temperature sensor
parsaria
I want to suggest that there should be a possibility to combine several temperature sensor in a room as one sensor.
That plus the possibility set a factor weight on a sensor.
It could be very simple to build as a linked device.
Select several sensor into a linked device, with a weight on it, like 1 , 2 or 3 as option, that means a sensor with weight 3 has more influence on the average temperature then weight 1.
Make sure that this linked device is selectable as main room temperature sensor,  also make sure that this device is selectable as sensor for the linked heating devices.
This way a lot of visual problems can go away, and you can have one average temperature in a single room, what makes more common sense.
Just a thought.
Thank you for sharing.
I have thought about that too.
I recently started a discussion which is somewhat related to this... Feel free to join the discussion or ignore it completely.
