knuth 29
I'm in the planning stages, and would like your comment on these plans:
1. I intend to use one RGBW controller to control two dual-white LED strips, each having two inputs (warm and cold white). One strip will be connected to R&G, the other to B&W. Control of color temperature will be through scripts/scenes. The RGBW controller will be located in the ceiling panel, near the transformer for the LED strip, on the low voltage side.
2. In some rooms I will have a regular LED lamp as well, controlled by a Fibaro dimmer. I plan to connect this lamp (220 V side) directly to the dimmer switch S1, while addressing the RGBW by S2 using an association to input channel I1 and I2 (or I3 and I4). On the RGBW controller there will be no physical connection to the input channels, as they will be controlled through Z-Wave. On/off and dimming will be achieved by switch S2, which activates both LED strip colors.
3. In other rooms, the LED strip will be the only light source. In this case, I would still like to hide the RGBW in the ceiling with no direct connection to the wall switch. Behind the wall switch, I would have liked to have a simple Z-wave controller, without a 220 V relay, which through association could address the RGBW remotely. As this does not seem to exist, do I need to install a regular Fibaro switch without a load on S1 instead?
5 answers to this question
