h2009 0
Hello
Wondering if someone can help me please. I've setup my zoned heating in HC2 heating panel and all my TRVs have external sensors which are reporting the temperatures correctly; however the issue I'm having is that the TRV's aren't opening the valves enough to allow the water to pass through the valves and hense there is no heating.
Can anyone suggest a fix for this - noting that I've got 22 TRVs to do this on.
A manual method is to turn the TRVs to max which allows the water to pass through.
Its worth noting that I was using Call For Heat Scene script by Dave Harrison however it was only running through the script once then never again.
HC2 - Firmware Latest
TRVs - Firmware Latest
Boiler Receiver - HRT4
Relay script:
9
9
8
Feb 2
15
Feb 3
15
Feb 4
10
Feb 5
2
adyboss 10 posts
petergebruers 9 posts
rls46 9 posts
h2009 8 posts
Feb 2 2018
Feb 3 2018
Feb 4 2018
Feb 5 2018
42 answers to this question
