Door Sensor / HC2 & Aeotec smart switch 6 troubleshooting
Guest CraigT
I am fairly new to HA, but having worked in technical fields I am familiar with tech, systems and how things work in general.
I need your help to troubleshoot an issue I have.
I have a
, and two
(amongst other things)
This issue is that the Smart Switches both turn off when the door is closed, and turn on when the door opens.
I initially thought the switches had an issue, as I didn't realise it was the door that "controlled" them.
I don't have these in a scene or in any groupings, and when the switch is turned off, the HC2 still sees them as being on.
I have removed both switches from HC2 and added them again, but they still act in the same way.
I also have checked the Alarm Panel, but there are no associations there.
Will be grateful if anyone could point me in the right direction to troubleshoot and overcome this.
Hi @CraigT
Have you tried resetting all those devices to their factory default settings?
