Home app says update available, Fibaro app says otherwise
Update is easy with the fibaro app normally as with the eve app from elgato, sure yes....but get that version checking code straight with apple and their home app pls, txs
Has this been fixed yet? I see no way to do firmware updates.
Not yet, still same situation....normally U C under accessory info: update available and U just click on it....they should get onto it soon !!!
my first post. thanks for posting this question, and thanks for the answers.  now I can mark this off my list of things to try and figure out this weekend.
Still no news on a fix?
No, Fibaro says Apple's baby....Apple says Fibaro's baby....perfect....can't be so complicated to quickly change the version checking coding in a small single App at Fibaro ...cu, macman (and I think it's Fibaro business, because it first appeared after the last Fibaro Home app update)
    Yeah, this is surprising to me too. It happened right after an app update. I honestly thought this was going to be a quick fix and we'd have already seen an update by now.
    Right, I try to check this next week with the apple developer section ...
    I found this on Apple Developer Forum
    Right, I tried to check this with the apple developer section ...
    Firmware versions still different, but at least the apple home app does not show firmare update available anymore and no numbers on the icon....
    The issue has been fixed and the Apple Home app doesn't show the update notification anymore.
    Cheers! : )
    Yes, see above...:-)
    Guest chaicka
    Cheers! : )
    What do we need to do?
    Mine is still showing updates needed.  Any hints on how to force a cleanup now that a fix is in place?
    KC
    There is no "clear cache" button in HomeKit so I've just restarted the phone and showed up at my house.
    I believe it won't fix via remote connection. So you should get in range of those devices.
    Guest chaicka
    I have rebooted all my iOS devices which are linked to HomeKit and HomeKit Hub (Apple TV 4th Gen) has also been rebooted. Still the 'Updates Available' shows up.
    Edited by chaicka
    @chaicka, since you were rebooting Apple TV, I assume you were near those devices that need the update? Or some other person at home made the reboot?
    Guest chaicka
    Yes, I am near those Fibaro HomeKit devices when rebooting each iOS device and Apple TV.
    Guest chaicka
    @I.Srodka
    Been trying various methods and it seems the Fibaro HomeKit Single Switch is the only device still getting prompted in Home app about firmware update available. Is there any other methods to try out without having to factory reset it?
    Hello @chaicka,
    We will most likely replace your unit. Contact me via PM and I will send you the details.
