[SOLVED]LUA Boolean Logic Problem
Guest jodohl
I have a scene that is suppposed to check a variable called "Snow" at Monday through Friday at 5 am and 3 pm and weekends at 7 pm and 3 pm. If Snow = "Yes", a scene is activated, turning on my outdoors heating mats for 2 hours (and at the same time resetting Snow = "No"). My thinking is to limit the use of expensive snow melting electricity to max 2 + 2 = 4 hours / 24 hours
The problem with the code below is that the scene triggers with variable Snow = "Yes" also outside the stated hours. What is it I am not getting right here ? I thought the AND operator had hierarchial priority over OR and that the code below would turn on the heater if the variable Snow = "Yes" AND the time is 5 am or 3 pm on weekdays or 7 am and 3 pm in weekends. But it seem to trigger whenever the variable Snow = "Yes", also outside these hours.
Help will be highly appreciated! (Scene 51 is the scene actually turning on the heating mats for two hours):
Best regards
Jo
%% autostart
%% properties
%% weather
%% events
%% globals
Snow
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
 ( ((currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "05:00") )
and
 ( fibaro:getGlobalValue("Snow") == "Yes" )
or
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "15:00") )
and
or
 ( ((currentDate.wday == 1 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "07:00") )
and
then
    fibaro:setGlobal("Snow", "No");
    fibaro:startScene(51);
5 answers to this question
%% autostart
%% properties
%% weather
%% events
%% globals
Snow
Hi @jodohl
Remove the Snow trigger variable from Your code.
BR
Guest jodohl
    Hi!
    I do not understand your advice. Remove the Snow variable...? The wole point is to trigger the scene at certain times IF Snow = Yes.
    this is Your triggers what You use to start the scene:
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    Snow
    every time when those variables change the scene will run , your scene based on time events 2 times a day, so You don't need Snow here , %%weather also is no need.
    Edited by domin12
    Guest jodohl
    Great! Thanks a lot !!
    This is what happens when a lazy person like myself convert code from block scene to LUA and start modifying without bothering to learn things properly.
    I have struggled a lot with understanding what "The scene will run" really means. Does it mean:
    (1) Execute the IF test and do nothing if the IF conditions is not true
    (2) Execute the THEN statement, regardless whether the preceding IF condition is true or false
    I guess (2) is what happens. This is equivalent to saying that you do not "trigger" the IF test. The IF test is one way of triggering. Manual execution another. And a change in one of the trigger variables a third. Am i right ?
    Edited by jodohl
    HI @jodohl
    I did not look at your scene how you use IF statement.
    In your case if condition is true then set variable Snow to NO, i think that this change of variable should be in scene No 51.
    i will change a little bit your scene and here You are:
    %% autostart
    %% properties
    %% events
    %% globals
    function tempFunc()
    if (
    and
    or
    and
    or
    and
    then
            --fibaro:setGlobal("Snow", "No"); -- move to 51 scene or move to the bootm as is now
            fibaro:sleep(5000)
    setTimeout(tempFunc, 60*1000)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    Edited by domin12
