Turning on/off Philips Hue bulbs in scene with the HCL Gateway
Hi there,
Is it possible to turning on/off Philips Hue bulbs in scene(blocks) with the HCL Gateway ?
If I use the Philips Hue plugin, I only can manualy turn the bulbs on or off. I can't see/select the bulbs in the blocks scene.
Michael Bakker
You need to install and configure a Virtual Device for every light or group of lights you would operate in block scenes.
Luckily there is the great job done by AkilliYuva
