How to remove mystery device when Force Remove fails?
There's a device in my unassigned group that I tried to remove using Force remove.
The notification window says: "NOP sending succeeded. "
Then:  "The device has not been removed. Please use Learning Mode to remove it.
I can't remove it in learning mode since I don't know what & where it is and therefore which button to press to get it to send a signal to the HC2.  It's just a cardboard box icon.
Any ideas appreciated
Hi @k1s!
I think you have used all interface options.
It's best to contact FIBARO support via email, they will try to remove it directly from the database.
