Joystick 2 Share Posted February 27, 2018 (edited) Hi all, I just bought some Qubino Flush1D relays to replace my Hunter Irrigation controller. The Controller/Valves are operated by a 24VAC Power supply that I would like to use for the Relays. Now, I am somehow stuck with the wireing logics... From what I understand: I need to connect 230V to the relay L/N , and the 24VAC supply to the Q (in/out) Ports, right? BUT: where and how do I connect the valve, can I connect 2 valves to one relay? I attached a qubino schema, maybe someone of you can help? Cheers joystick Edited February 27, 2018 by Joystick Quote Link to post Share on other sites
Joystick 2
Hi all,
Cheers
joystick
Link to post
