Hello guys
I have 2 single Fibaro switches. One connected to the light and a wall switch and the other one only to a wall switch.
I am simulating a 2-way circuit here but should be done on z-wave or HC2 level
So both switches should follow each others. I turn on one, the other should be turned one and vise versa
Maybe i can use device association in Z-wave but i don't prefer so
Any ideas?
Hi!
the same situation. I do not know how to make it via association.
so. LUA.
as I can see you have HC lite... maybe can implement via blocks.
