Hi
I am new here, so sorry if I post this at the wrong forum :)
I'm using fibaro HC2 together with google home  by ifttt.
I have created a user who only has access to a virtual device that I send the http command to.
It works fine when I using device ID directly:
http://User:Password@/api/callAction?deviceID=93&name=turnOn
but when i usen the button indside the virtual device, it dose not work at all:
     http://User:Password@/api/callAction?deviceID=201&name=pressButton&arg1=button0
and I am getting the virtual device ID from the http link:
/fibaro/en/devices/virtual_edit.html?id=201
I have no idea why it dose not work, its pretty Straight froward?
thanks in advance for your inputs :)
Edited by DonZap
20 answers to this question
For example: These are the strings I am using for geofencing:
3
As you can see in the screenshots the 2 and 3 at the end of the string are a direct mapping to the label and buttons, not the ID.
This number is a counter and can change if you add buttons and labels.
If I for example add a button on top it will effect the count and then I need to change the strings to 3 and 4
So I am not using the ID of the label or buttons.
If this doesn't solve your problem there must be something wrong else, besides this.
But I think you need to fix this too.
When you try to run the string, are you running them from a browser like IE?
Maybe try a different brower, Chrome for example.
Hope this will help you a bit further.
greets,
Remi
    There is really nobody  who can help me with the problem and tell me what i am doing wrong?
    Hi
    Not sure but I think you need to use the button number 1 or 2 or whatever number of buttons you have, instead of "button0"
    /monthly_2018_03/Capture.JPG.ccc6d337bd7f01dbda72766b4d3d9b75.JPG" alt="Capture.JPG.ccc6d337bd7f01dbda72766b4d3d9b75.JPG" />
    You're calling to virtual device using webhook in Iftt? Then you need to define ipaddress (external) to http line
    it should look like http://user:password@ipaddress/api/.....
    don't forget to forward traffic to your ipaddress to HC2 in your router. See portforwarding instructions if you don't know how...
    sccs
    Hi Reintjan
    Thank you for your reply.
    I've done everything that you describe there.
    As I wrote, it works just fine, when I am using det device ID directly in the http link:
    but as soon as I use virtual device, it does not work.
    so the reason is the virtual device configuration, but I just can not figure out what?
    Edited by DonZap
    Hi Remi
    I have tried that too, it dose not change anything:/
    I don't see the ipaddress in your link. If you're trying to push the button using ifttt ipaddress must be used in the link otherwise it does nothing.
    So in the link use ipaddress after @ sign. You have to use external ip and set forwardrule in your router to lead traffic to your homecenter
    Edited by Reintjan
    I would recommend, you are setting up another account in the HC2 and use that user and password, and not the username and password from administrator or own account
    2
    deviceID = needs to be set by user according to their VD
    pressButton = needs to be set by user according to their VD
    Edited by samuel
    Reintjan:
    yes offcourse I have the ip adrress in the link, otherwise it would not work at all, this one was just an example :
    mine looks like this:
    http://User:Password@IP:Port/api/callAction?deviceID=201&name=pressButton&arg1=button0
    Samuel:
    yes it is exactly what I have done ,I have created another user that only has access to the this virtual device.
    I will try that again just to make sure that i didn't missed anything last time.
    But what are you using as IP adresse for your virtual device, you are using port 80, so you probably using some web-interface?
    I will off course try this too, regarding the browser, but it should not influence the result, since this one working just fine:
    http://User:Password@IP:Port/api/callAction?deviceID=93&name=turnOn
    hi
    http://USERNAME:PASSWORD@IP:PORT/api/callAction?deviceID=614&name=pressButton&arg1=2
    this definitely works as i use all the time. amend the device ID to yours ie 201 and the number 2 at the end to represent the button number you wish to press.
    @DonZap  your ID of the Button is not the name you gave it in the webinterface.
    We had the same topic in here
    Your command should look like:
    http://User:Password@IP:Port/api/callAction?deviceID=201&name=pressButton&arg1=1
    Edited by bl5cky
    Adding sentence
    Honestly I cant remember why I put in those "" in the IP field and 80 as port number.
    My best gues is the "" is replacement for leaving the IP.
    But I don't think its of any use since I'm not pointing to any netwerk device either.
    First step for you is the fix the button ID to the correct button number.
    If you havent already done so, maybe its a good test to try the string on your local network first, with local IP of the Fibaro controller.
    If that's working, maybe your port forwarding rule has an error.
    I am at work now so I cant check, but I think I forwarded port 80 to 80 in the router.
    Edited by Remi
    Remi:
    it did actually did the trick:
    /monthly_2018_03/image.png.f92a53a43abdc541a05ccd4f2a758cb3.png" alt="image.png.f92a53a43abdc541a05ccd4f2a758cb3.png" />
    I have no idea why it is possible at all and what it dose, but works, thank you very much  :)
    Best regards
    Zap
    That's great! Glad its working!
    I think the local host IP (127.0.0.1) messed it up.
    Leaving the IP field empty would have solved the problem too, I gues.
    Will test that tonight for fun and to learn :)
    Many of us are concerned about the security of IFTTT Webhook accessing  HC2 via basic authentication. People have generally tried creating a new user and limiting the rights for that user. For those even more paranoid about security, there is another, more sophisticated solution (tried and tested):
    • IFTTT Webhook sends commands to ThingSpeak channel via API
    • ThingSpeak channel data insertion triggers a Matlab analysis app in the cloud. You can use this app to generate a mathematical encryption of the command you want to forward to HC2. Sky is the limit for encryption here (you can read the Cryptonomicon for insipartion:)
    • ThingSpeak sends an HTTP API request to HC2 to trigger a scene with the encrypted command in the body of the request (to be used in fibaro:args())
    • HC2 Scene processes takes the command from the fibaro:args(), decrypts it and takes appropriate actions
    Here are the reasons this solution works:
    • You have all the versatility of IFTTT
    • You have the flexibility of ThingSpeak Matlab - you can post process and encrypt...
    • On HC2 you only have to give the 'IFTTT user' the right to access that one scene that decrypts the command and takes action
    Speed is ok - requests triggered by IFTTT take 2-4 seconds to be executed by HC2.
    Unless Fibaro develops a genuine IFTTT service, the above is the most secure and versatile solution I've come across.
    Also the Google Assistant integration of Fibaro is a joke. But with the above you can do anything you want with GA via IFTTT service - devices, scenes, global variables, all of it together, etc.
    Edited by Ros
    have you guys had success with controlling the fibaro dimmer  by IFTTT and fibaro?
    let say that we want to set the dimmer to a specific value, 10-20-25-30 and so on.
    My slider link looks like this:
    http://<IP>/api/callAction?deviceID=<ID>&name=setSlider&arg1=<SLIDER ID>&arg2=<VALUE>
    but how can I make the arg2=<Value>  as variable and not a fixed value.
    I am using google assistent as tiger by sayin: "set the kichen light to # precent", but how can I use # in the frase as value for arg2, so i don't have to create a trigger for every step, like 10-20-30 precent  in the vartual device and IFTTT app ....?
    No one, it may not be possible!?!?
