Is it possible to change a scene icon in LUA?
The scene is just a simple toggle:
9 answers to this question
Do you mean something like that?
/monthly_2018_03/5a9e7a753020e_ChangeIconScene.PNG.fa7543c9305d52a362f2b6073389cad2.PNG"> Scene changing icon.gif
Of course, the most vital part is:
Hi @mazzurra!
Could you develop your idea? What do you mean?
With a toggle in one place you would like to change the scene icon of some other scene or what?
    Yes I would like to change the scene icon using code. For example when I run the scene I want  to change the icon of the scene. Would this be possible?
    Your my hero! This is what I have been searching for too! :)
    Is it also possible to change the icon for the same scene where the code is?
    With the above example I only managed to change icons for other scenes.
    The moment I change the id to the scene itself it doesn't work well anymore.
    I have been looking for this!, thanks
    Thanks @I.Srodka, was exactly what i was looking for.
    Hi!
    In a nutshell, when the "icon change code" is at the end, it is possible. However, the icon change requires the scene to reload so you should better change the scene from another scene.
    Can anyone confirm, does this api call still work?
    api.put('/scenes/49', {iconID=3})
    Edited by Jamie mccrostie
