xirilius 0
Is it posible to send text to a cell in a Google spreadsheet from Fibaro Lua?
My central heating is a zone-heating controlled bij a Fibaro HC2 with zwave Secure thermostats in every room in my house.
The heating works by a central gas boiler and electric Heimeier valves with Fibaro relais
I like to log the on/off times (then i can calculate the heating minutes per day) so that i can show it in a graph according to the room temperature and outside temperature.
With this information i can make my heating even smarter, i can automatically calculate the starting time to heat in the morning depending on the room and outside temperature to reach a certain temp at 9:00
If sending text to a external document is possible it can be used for a lot of other things:
- Temperature logs (pir/smoke sensor)
- Room usage (pir)
- Usage of devices (koffeemachine, radio, tv, computer, lights, .....)
- Graphical views
