1) Does somebody know what the size limit is for the 'message' variable in Lua sendEmail
fibaro:call (2, "sendEmail", subject, message)
I am sending automatic generated log files to my email but sometimes i receive nothing,
after decreasing the number of lines i receive the mail.
2) And can Fibaro Lua return a error (number or text) in a variable using this sendEmail command?
Thanks!
depends of character set, I tested with maximum 1247 characters
You can check info about limits here:
Test was done on 4.130 for all stated limits, but even now on 4.160 there is still same limits for LUA code length in scenes and VD's so I believe that other limits are still the same.
