knuth 29
Having tested my new HC2 a while, I am now ready to install it in our new house. During testing several device numbers have been allocated, some still active, some "orphan" following delete/reinstall sequences. I now have two questions:
When the maximum device/node number (node id = 232) has been reached, will HC2 automatically start assigning unused/orphan numbers from the top of the list? From other non-Fibaro forums, I have learned that some gateways do this, while others just stop at 232 and can go no further, even if several device numbers are unused. What about the HC2?
I plan to do a "Reset Z-wave" before starting my real installation. This will delete all my test devices, which is fine. Will it also reset the numbering, making my next installed device number 2? Or will it still continue from the last device number I have used before reset?
Edited by knuth3 answers to this question
