kintrupf 0
I recently got a used Roller Shutter 2 to try it out. Before wiring it to the switch and motor I wanted to check it and include it into my Z-Wave network.
I attached the two power wires to the N and L port of the device, plugged the cable into a socket near my Z-Wave controller and tried to initiate the inclusion process, but to no avail.
Resetting the device as documented in the manual does not seem to work either, the device appears to be completely "dead"
So my question is: should the Roller Shutter 2 work with only the power cables attached or do I need to attach ALL wires before I can include it into my Z-Wave network?
Thanks!
6 answers to this question
