Expected value but found T_END at character 1
BitBucket
Hi all,
I am struggling with a weird bug that happens on a very irregular basis (once in weeks, or lately 2 times in 1 week at night).
The VD controls my home heating. After is crashes, it gets cold.
Sometimes decoding the json string kills my VD 'Main', fatal error: "Expected value but found T_END at character 1".
'User' has admin credentials to access the heating panel. If I deliberatly corrupt username or password, I get the same error.
For performance reasons, authentication is done once as 'Main' never ends. Function HeatRoom() runs every minute.
It looks like 'panel' from HC2:GET is an empty string once in a while but why?
Is it possible for authentication to expire?
Any idea about the cause/trigger and a fix?
5 answers to this question
use instead following:
  • @tinman +1, works perfectly and username + password no longer needed in VD.
    @T.Konopka, @I.Srodka and all other experts.
    For future code, to avoid the initial problem, I would still like to get some answers to my initial post.
    Thanks in advance.
  • @boerremk thx for your code. to avoid VD stop on error.
    Problem is, the panel is needed to control the heating.
    I could wrap this in a pcall( .... ) and retry a few times.
    That would work but I rather know what the root cause is.
    Maybe a security feature, may be a bug.
    So the questions are still open!
    Have you solved this problem, I have the same as.
    Regards
    Nilmoty
    Edited by Nilmoty
