"sendPhotoToUser" command not working anymore
Hi
I recently figured out that my scenes with sending picture to e-mail from a ip camera not working anymore. It stops working around November 2017, I think after update to 4.150 or 4.140.
Now running 4.170 on HC2 and command "sendPhotoToUser" not working.  Button with camera logo on the device which used to send a snapshot to mail, also doesn't work.
Has anyone else same issue?
Code which should send a picture looks like this:
Exactly the same code coming from  block scene, when I making new scene now and converting to lua.
Camera's settings and plugins/for cameras wasn't changed since this worked.
10 answers to this question
    Anyone???
    i have the same problem. did you solved it ?
    Guest dobsovicj
    There is a problem with notifications generally now...
    Please wait with testing when FIBARO solve the issue with notifications.
    BTW, I´m using sendPhoto and it is working for me (of course, not now :-)  due to the generally issue)
    Is still not working. What interesting thing is that I have doorbird intercom connected also to HC2 via Onvif protocol and is working fine. Only Hikvision cameras has a problem..
    How did you connect Camera/Intercome via Onvif??
    My script sends two photos from different cameras by pressing the bell (UBS). Unfortunately, he sends two separate messages
    Cytat
    %% properties
    264 value
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(264, "value")) > 0 )
    or
    then
        fibaro:call(262, "sendPhotoToUser", "2");
        fibaro:call(257, "sendPhotoToUser", "2");
    In the simplest way :)
    Add device -> ad camera-> choose camera model "other model"
    Fill up IP address, and user/password and jpeg path (for doorbird is: /bha-api/image.cgi )
    When Onvif capabilities on intercom are disabled, it will denied access for HC2.
    My Hikvision cameras are added in the same way, which obviously will not work with "sendPhotoToUser" command
    Which camera model/manufacturer do you have?
    I have different cameras - noname. My DVR supports jpg and jpg and he gives me a picture for fibaro.
    /monthly_2019_06/kam.jpg.ea9f68f0971a9fb92785a152e9f0ddf4.jpg" alt="kam.jpg.ea9f68f0971a9fb92785a152e9f0ddf4.jpg" />
    Witam chciałem przenieść scenę na HC3 i brak opcji sendPhotoToUser a i na samym początku wywala błąd
    "local startSource = fibaro:getSourceTrigger();"
    [SCENE52]: (load):1: attempt to call a nil value (method 'getSourceTrigger')
    Ma ktoś to poprawione ??
