Hey All,
I created a "scene A" light on and after 10" licht off via a wall plug, this scene works fine.
Now I create "scene B" as follows: If KeyFob "button 2 press hold" then "scene A". This "scene B" does not work. What is wrong, anyone an idea? To activate a scene from an other scene must be possible isn'it?
Thx for your replies.
4 answers to this question
try the following:-
fibaro:startScene(sceneID)
  • sceneID: The number of the scene which is to be started.
    The command startScene is written down in the script. See LUA script hereafter with KeyFob button 1:
    /monthly_2018_04/SciptLUA.jpg.3bc70883d71dc7383680d8c65e180a88.jpg" alt="SciptLUA.jpg.3bc70883d71dc7383680d8c65e180a88.jpg" />
    I have a similar setup like you want to implement. My code is working. Difference with yours is that I have
    if (
        -- Perform action on RC click
        startSource["type"] == "event"
      or
      then
    So I do not have you AND clause.....
    I don't really understand why You nreed the "if" part.
    What are the ways to run the scene?
    I can see 2 options:
    1. hold the button
    2. start scene manually.
    And both options olways return true i the "if".
    So the code should be (it changes nothing in fuctionality, if I didn't miss some "if" params):
    (don't trust it, there might be some misspellings) - OK... this was out of scope of question...
    SO THE REAL WAY TO FIND THE PROBLEM AND FIX THIS:
    You need some debuging.
    First of all chack of the scene B runs. Just write: "print('works')", and check the result in debug window.
    Check if fibaro:startScene(56) starts when it's at the begigng of code, before any "if" statement.
    Print the values of variables in "if".
    Print inside the if some debug, ie: print("i'm inside");
    I'm new to LUA, but I'm programming in other languages for 10+ years, and that's the thing I always do in sitiuation where I can see no problem in code but something's not working.
    Edited by pogo
