Aeotec Garage door Controller Gen5 - Log and other devices
Inge
I have a Fibaro HCL With some different Fibaro Z-wave units...and i bought the Aeotec Garage door Controller, its Nice to open and Close garage from the app - BUT the description told me that i could see a LOG for when the garage door was opened and closed, and i could Connect other Z-wave external Devices, f eks a camera that can start when the garage door opens, or maybe a light that come on when the door opens and shuts off when the door Closes. Aeotec say this needs to be done by Programming the Fibaro Controller, but i cant find any Place how i can make a scene or make a setup for this. Anyone have experience With this and can help?
I can only see if the door is open or closed - see photo under here. The photo With the blue circkle around is what i can see aboue the Aeotec Garage door Controller.
Kind regards, Inge Nordgaard
Hi
Maybe I can still help with an idea.:)
I have a lamp that changes color when the alarm is set and it changes to a different color when the alarm is off.
Garage door must be found when you make criteria in a scene, and then turn it on to light or change color on a Zipato bulb.
There are probably some with other ideas.
Hi Inge.
Did you manage to fix the event log problem?
I have the same Aotec opener, and it is connected to my Fibaro HC2 controller.
In my installation I manage to open and close the garage door from Fibaro HC2, and the status "opened, closed" shows correctly.
BUT the event log does not show events for the Aotec opener ?
Best regards, Eirik Flaten
