chapa 3
Hello Community,
Recently, I updated my HC2 from 4.160 to 4.170.
Today, HC2 stopped responding to zwave sensors, I was able to login to web interface and see that.
CPU and Memory were all fine, even I think CPU was a little bit calm than usual.
As usual in such a case of "block", I went to Configuration and clicked Restart.
Unfortunately, my HC2 never come back operational.
Tried restarting it several times, every time same, stuck at "Starting Services".
I see HC2 is responding to ping.
Also I observe continuous z-wave led flashing first 4-5 minutes after restart.
Than only the three right led stay on.
After 4.16->4.17 update, I had added few Fibaro Door/Window 2, configuring other old devices, also.
Also upgraded a few Heat Controllers to 4.3 firmware (was pain).
I am not sure if it was before or after the update, but I also added around 10 Fibaro Roller Shutter 2.
The setup was working fine for around a week since now.
I have around 50 physical devices, mostly Fibaro ones. A few VDs and Scenes (being there since 4.14)
Does anyone has any suggestions apart from reset and restore procedures?
Can it be ZWave Services (or soem other system ones) refuse to start due to some reason and the UI also waiting upon them, staying at "Starting Services"?
Any ideas?
Thanks.
26 answers to this question
