Guest andyhud
Hi Guys
I'm in the UK and have a Fibaro Roller Shutter 2 Module hooked upto a Dooya DT52S-75/20 Electric Motor Rail
The DT52S has 2 Lives (Brown and Black) which connect into Q1 and Q2 on the Fibaro RS2. Power to the brown side makes the motor close the curtains and Power to the black side makes it go in reverse. Simple.
This has worked fine for a 3/4 months now but I took my curtains down to add some more hooks etc and then I recalibrated my RS2 but now when the curtain rail reaches the fully closed position it keeps trying to close forcing the motor and curtain rail to shake violently.
To illustrate this I have recorded a video of my setup and what happens and you can view that here:
I would be grateful if anyone has any input/suggestions as to what to do. I've got 4 electric curtain rails in total and 1 of them calibrates fine! But the other 3 have this issue as in the video. Whats important to note is when I first put these up it calibrated fine first time!
I have removed the RS2 from my HC2 and factory reset it and re-included it but no luck so any advice is appreciated.
Picture of model of electric curtain motor model is attached.
Thankyou in advance!
Andy
