tylkologin 2
I've a garage door with Came V600 engine and Came ZL55 mainboard. I decided to use Fibaro keyfob to open and close garage. My steps:
1. I connected a momentary switch to pins 2 and 7 on the mainboard. After pressing the button garage opens, after second press the garage closes. So far so good.
2. I disconnected momentary switch.
3. I bought Fibaro Relay Switch FGS-212-EU-v2.2 and made connections as follows:
L - 24VDC
N - 0VDC
Q - pin 2 on the mainboard
IN - pin 7 on the mainboard
4. The relay switch is visible in my HC2, so I change several options:
a) Controlled device - other device
b) Parameter 4 - 1s
c) Parameter 14 - momentary switch
5. Now I can click instead of press button. Unfortunately nothing happens. So I've changed Parameter 4 to 0.5s. It didn't help.
What am I doing wrong?
Kind regards,
Michal
7 answers to this question
