Global Functions in Fibaro HC2 LUA?
Is it posible in HC2 LUA to create global functions?
I use o lot of functions over and over again and have to include them in every scene
Is it possible to create functions in a centralized scene and use them from every other scene?
Example:
GlobalFunctions
global function BeepXseconds(x)
   fibaro:call(42, "turnOn")
   fibaro:sleep(x * 1000)
   fibaro:call(42, "turnOff")
global function MyDebug(text, color)
   -- read GlobalGlob
  if DebugGlob = true then
       -- do something with formatting text, add OS.date and add colors
      fibaro:debug(text)
now i can use the global functions in other scenes
scene 161 - TurnAlarmOn
-- do something
MyDebug("Turn Alarm on", "red")
BeepXseconds(5)
-- do something
scene 254 - Doorbell
-- do something
MyDebug("Someone is ringing", "BLUE")
BeepXseconds(2)
-- do something
AND OFCOURSE I CAN CREATE SCENES AND USE THEM LIKE GLOBAL FUNCTIONS
BUT PARSING VARIABLES IS NOT THAT SIMPLE,  I THEN HAVE TO USE GLOBAL VARIABLES
REAL GLOBAL FUNCTIONS (LIKE A LIBRARY) WOULD BE GREAT !!!
Edited by xirilius
Link to post
17 answers to this question
Not necessarily by using global variables, you can pass parameters to a scene.
Suppose you want to pass an  ID and a Value to another scene. Sending scene:
fibaro:startScene(207,{1437,99})
Receiving scene (this has ID 207):
local id,value=fibaro:args()[1],fibaro:args()[2]
fibaro:debug(("args: %d %d."):format(id, value))
Link to post
Haven't tested this really, but this is a concept of how a homemade 'require' could work.
require(sceneID,module_name) checks if the  calling scene has the same version of the module as is in the scene with sceneID. If yes it just returns the local module, otherwise it patches in the module code from the other scene and  aborts. If the scene has autostart it will restart with the new code.
When require is called the module code needs to have loaded, that's why we call a 'main' after the scene is fully loaded.
If scene 320 looks like this (the Library scene) ( a library scene can have many modules)
module_foo = {
  version = 57,
  loader = function()
    local self,b,c = {},58,67
    function self.test1(a) return a+b end
    function self.test2(a) return a+c end
    return self
and scene 319 looks like this (the client scene), it will patch in the new module from 320
function main()
  foo = require(320,"foo")
  foo.test1(2)
  foo.test2(3)
-- do setups
function require(sceneID,mod)
  local scene = api.get("/scenes/"..sceneID)
  local libcode = scene.lua:match("(module_"..mod.."%s*=%s*%b{})")
  local version = libcode:match("version = (%d+)")
  local loadedLib = _ENV['module_'..mod]
  if loadedLib and (loadedLib.version == tonumber(version)) then
    return loadedLib.loader()
  else
    scene = api.get("/scenes/"..__fibaroSceneId)
    if loadedLib then
      scene.lua = scene.lua:gsub("module_"..mod.."%s*=%s*%b{}",libcode)
    else
      scene.lua = scene.lua:gsub("---------- Library -----------",
                       "---------- Library -----------/n"..libcode.."/n")
    api.put("/scenes/"..__fibaroSceneId,scene)
    fibaro:abort()
module_foo = {
  version = 56,
  loader = function()
    local self,b,c = {},53,66
    return self
-- call main
main()
Link to post
i am not realy understand.
tell me if i am rong
you want a global that have al the globals you need and refer them in a scene, something like the Hometable??
Link to post
As far as I know your only option is to store the "global function" some way (e.g. json formated) in a global variable and import it where it is needed.
Link to post
@petergebruers hi!
can help me?
scene id 123
function checkTime()
	local args = fibaro:args()
  	if #args > 0 then
      local str = args()[1]
      local t = os.date("*t",osTime());
      local h1,m1,h2,m2 = str:match("(%d+):(%d+)-(%d+):(%d+)")
      m1, m2, t = h1*60+m1, h2*60+m2, t.hour*60+t.min
      if (m1 <= m2) then
        return m1 <= t and t <= m2 -- 01:00-02:00
      else
        return m1 <= t or t <= m2 -- 23:00-21:00
	return false
calling
fibaro:startScene(123,{"18:00-22:00"})
my question is -how I can get function result?
Your workaround OK for calling, but FIBARO how that deaf can't understand what all users wish declaring a global function...
PS: please do not recommend me "remove tonsils through the anus..."  ;D  I want simple get a result from a function...
Link to post
So, this is one of the reasons that I'm working with an 'event' based model when programming my scenes. I have scenes that send requests to 'library' scenes that perform some functions and return results. The implementation uses startScene and attaches the scene ID of the calling scene so the 'library' scene knows where to return the answer. However, it becomes asynchronous so it is easier if the whole scene logic is based on events. Here is an example that calls a scene that looks up users in Apple's iCloud. (the iCloud code is not included)
I have a new approach with a 'scripting' language that can hide the asynchronous nature of the call and just allow for ex. "location=callILocator(credentials)"... I will shows some examples in a later post in the thread below.
Link to post
dear @jgab you as always cool :)
I am learning LUA by your code, it's true. but now I am simply asking to implement easily including user library in any scenes / VDs for example via LUA FIBARO header
Link to post
Yes, you're right. Fibaro should find a way for shared user libraries. The best way would be to support Lua's 'require', but they would need to find a place to store the code - some new type of scene, call it library? The other issue is possible code/scene bloat as people would start to include a lot of 'good to have' code... :-)
Link to post
%% properties
%% events
%% globals
%% using
34
orabif:test()
-- 34.lua - scene #34
local orabif = {}
function orabif:test()
  print("Test!")
return orabif
Edited by 10der
Link to post
1 minute ago, jgab said:
-- do setups
Aaaah! @Fibaro  Do you even know what you're doing? :oops:
Link to post
the regexp parsing of module is a bit too simplistic. e.g. can't have mismatching brackets in strings inside the module code.
A trick here is to use the _ENV table that holds all available globals and functions. Normally Lua has a _G table, but here we have a more limited table _ENV. However, it is still useful for calling functions or accessing variables given their names. The closest to meta-programming we have in the HC2 environment..
Link to post
What do you mean? __fibarosceneid only defined in scenes, so this only works in scenes
Link to post
sorry, I am still talking about cost and how owner HC2 developers trying to find workarounds for require
Don't mind me. I was just leaving.
Link to post
Do you know if HC3 has a better way of handling require?
AFAIK, here the only option is to put the definition of this require() function to every scene in which we want to use libraries, right? It'd be great to have something tidier...
If this is supported in HC3, it's a good reason to upgrade...
Link to post
It's easier - on the HC2 it was high-wire acrobatics. On the HC3 it's more like a ground floor somersault.
The HC3 QAs (VDs) have can consist of several 'files' and you can pull in files from other QAs or over the network (like your Github) with common code. There are a couple of examples in the forum. I have a module system I use myself for all QA code on the HC3 <link>
Link to post
  • -1
@jgab it's really cool but
[skipped...]
Link to post
