Elkin 0
I'm aiming to wire in the Single Switch for a kitchen extractor fan on a lighting circuit that is switched physically at the wall. This means it would be power cycled several times a day,. So my question is... would that stress the unit to be power cycled so much?
Background to the use case is that it is helpful to have the unit switched off with the rest of the lights manually, without having to switch it off separately, and the fan will not be needed if the lights are not on. Also, there is no unswitched power supply very nearby, so it would be a bit more work to make this operate as intended.
Thanks.
