I have installed the Fibaro Double Switch 2 with Samsung SmartThings as the hub.
Using the official device handler from
For some reason I do not see two switches after connecting it to the hub, but only one.
I also get an error saying: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again".
I removed it and added several times but the error still returns.
Any advice on what is wrong?
I have the same thing. What is happening?
    I found this device handler that does recognize it as two switches.
    not sure what is the bug with the official device handler.
    Hi, thanks for sharing.
    ST is a great btw. Since las week I also have it. And I am impressed how easy can arrange any device integration.
