Push-dim / switchdim what Module to use
kroeatschge
Hi guys,
i have installed dimmable LED Strips.
They are powered by DALI drivers from tridonic as mentioned in another topic.
As I don’t want to go the dali route I want to use the push-dim feature which is also supported.
I have installed Fibaro single switch 2 modules. Unfortunately I can’t push-dim with them. At least I haven’t found out how.
They only switch on and off.
What module do I need to be able to long press my toggle switches to get push-dim working?
Short press should toggle on/off and a long press (as long as I hold the button)  should dim up/down.
Thanks for hints.
kro
/monthly_2018_05/276C635C-8DE7-4847-97E0-E396ECC0E4F0.png.e95bfe13730998bd13a84d84a326e4a1.png" alt="276C635C-8DE7-4847-97E0-E396ECC0E4F0.png.e95bfe13730998bd13a84d84a326e4a1.png" />
9 answers to this question
On 6/5/2018 at 12:27, kroeatschge said:
Hola chicos,
He instalado tiras de LED regulables.
Son alimentados por controladores DALI de tridonic como se menciona en otro tema.
Como no quiero ir a la ruta de Dalí, quiero usar la función push-dim que también es compatible.
He instalado 2 modulos de conmutador único Fibaro. Desafortunadamente no puedo presionar con ellos. Al menos no he descubierto cómo.
Sólo se encienden y apagan.
¿Qué módulo necesito para poder presionar por más tiempo mis interruptores de palanca para que funcione push-dim?
La pulsación corta debe activarse / desactivarse y una pulsación larga (siempre que mantenga presionado el botón) debe atenuarse / atenuarse.
Gracias por las sugerencias.
kro
Good morning, could you solve it?
Guest fat
Switch 2 modules are not able to dim, they can only switch on or off. If you wish to push and hold to dim you will need a Dimmer 2 module with momentary (bell press) switches and depending on the load may also require a bypass 2
On 5/6/2018 at 6:27 PM, kroeatschge said:
Hi guys,
Thanks for hints.
kro
I have exactly  the same problem,
Trying to use a Fibaro module to control LED Push-Dim driver.
Fibaro Dimmer 2 is designed for  Triac Phase-Cut driver so there is no use to it in this application.
Push-Dim driver are controlled by regular Momentary Switch (Push Button - Short press Toggle on/off, Long Press Dim),
So, My logic says you can use Fibaro Switch with Momentary Switch Connected to S1 to simulate the action of a Regular Momentary switch or Push Button.
You can use the Auto off function with time parameter set to 0 to create the fast ON/OFF action which is like short press on the button , this will turn the lights on/off , tested it and it works.
Still didn't find the right solution for simulating the long Press for the Dim function.
If you found any solution please share.
Thanks.
Roni s.
  • hey guys,
    look what I found
    . Maybe sunricher is solving this issue finaly for us:
    SR-2411-ZV-DIM a Z-Wave to DALI convertor. Not specifically a push-dim solution, but I think most push-dim are DALI dimmers.
    Unfortunately no place to buy it so far.
    BR - kro
  • I asked the guys of robbshop about the sunricher devices.
    They try to order some and provide them in their shop ?
    br- kro
    On 3/8/2020 at 11:36 AM, kroeatschge said:
    hey guys,
    look what I found
    BR - kro
    Hello guys
    I'm in the same situation here :)
    I have a LED Luminaire driven by a OSRAM OTi DALI 50/220-240/1A4 LT2 FAN (I can control it with ON/OFF, PUSH-DIM or DALI).
    Thanks kroeatschge for the Sunricher tip. Have you been able to test it ?
    My understanding is that using the dali interface would require a DALI bus already in place... with a DALI power supply on that bus (which I don't) !
    Cheers
    V
  • hi @vly,
    no, unfortunately the device is not available anywhere.
    It only appears in some PDFs.
    The only available options are for Zigbee->Dali like
    If you are in the lucky situation to have a controller that also supports Zigbee you can try that device.
    BR - kro
