Jibran 2
Recently , I tried to install Fibaro system in My friend's home. He wants to illuminate his all outdoor leds ( 5W, 7W, 12W) respectively.
I connected home center 2 (Entrance Main lobby) and then Fibaro single switch 2 (outdoor entrance) . The distance between them Is hardly 12 to 13 meters. Sometimes it runs sometimes it gives communication problems. It is not stable. Then i tried to connect one more relay between them to settle the signal problem . But same problem is still there.
Same is the case with all the outdoor Modules. 3 modules ( Relays) are connected just for the signals enhancement between CORNER modules so that there will be no signal problem . But the problem persist .
There is a Place (Storeroom ), where relay is perfectly working , But outside the storeroom, there are switches which are connected with relay, do not work( Communication Problem) and there is hardly 3 to 4 meter distance between storeroom switch (inside) and outside switches.
Also tried to change the position of the controller at every possible place but problem is still there.
Sometimes controller give communication problems just as near as 7 meter .
Device : Homecenter 2 ( 4.180 firmware )
Module : single switch 2 ( 3.3v )
Please Help me with this issue , as it is creating serious problems .
Thankyou
11 answers to this question
