Garagemotor problem
Andeb
I have a garagedoor motor which i don't know how to connect
The motor only have a place for a wall button. The wall button should get connected to Ground and PB.
But how do I connect the Fibaro roller shutter 2, all instructions I can find have 3 places to connect. One button up, one down and one ground...
Here is the sheet that shows the board
Use a fibaro relay not a roller shutter
Your relay will need 240v feed.
The relay switch contacts “in “ and “Q1”need  to be wired to the same contacts that go to  the door switch.
You will need to fit a seperate door sensor if you want indication of wether door is open or closed.
I have an identical setup as Jamie describes, with a Fibaro swich.
I built the switch into the motor housing, taking 240V from the power inside that box, and connecting the IN and Q1 parallel to the wall switch.
For the indication of the door status, I use a Vision Garage Door Detector (ZG8101) because it triggers on the position of the detector (vertical or horizontal) instead of on a magnet. But you could use any door sensor.
