Fibaro Dimmer
Akshay
Is it possible to connect the fibaro dimmer to the ceiling fan, whenever I m connecting to it doesn't turn on and the notification showing CAUTION electric surge detected
Need help with this
9 answers to this question
" to "
Temat został przeniesiony z "
" do "
This notification hints at it being improperly connected. We'll need more details. What kind of a fan is it etc?
  • 1.Orient Summer Delite Decor 600mm Ceiling Fan
    2.ORIENT ELECTRIC SPECTRA 1200 MM, BRUSHED BRASS FAN
    Sweep Size:1200 mm
    Speed:320 rpm
    Air Delivery (Mtr Cu./min.:230
    Wattage:70w
    Okay, and are you sure everything is connected properly? I mean the wiring, as this notification hints at issues in this area.
    Here's the manual. You can look for it there.
